Global Wrestling Alliance
a forum for the TWG fed GWA
HomeCalendarFAQSearchMemberlistUsergroupsRegisterLog in
Share |
 explaining GWAs power structure.
AuthorMessage
The Sound
The Sound
PostSubject: explaining GWAs power structure.   Fri Sep 23, 2011 8:46 am
when reading through t the bios here you will realize that as for now GWA has a complicated structure of Power. this is because I wan't to create a environment with onscreen backstage politics witch everyone in the fed is welcome to take part in, but to make it easier to explain where we stand I have made this power structure chart. this will be changed as time goes by and the structure changes. The longer up on this page a character is the more power does they have, although some like the COOs assistant Ashley Thomson who has no real power but is manipulating those who have will be placed in a position fitting to the power she can use but will be marked with a *. cliking on the link will bring you to the persons profile. if two persons got the same amount of power they will be put beside each other
The Sound
The Board of Directors
Andrew Jackman - Conor "The Rose" Anderson - Ashley Thomson*
The Deathangel - (IBs GM)
I will probably put player NPCs and Wrestlers at this list as well, but it will only future those who have (kayfabe) power enough to make or change matches and you can expect this list to get longer and longer as time goes by, either that or I will find a complicated power structure to much to handle and simplify it all Razz
Back to top Go down
View user profile http://globalwa.norwegianforum.net
Back to top
Page 1 of 1
» power chips or modules
» Duro Power-Grips ,25x8x12,25x10x12 $125.00
» Power Steering?
» ESP, Fox power gum, fox rigging and trace wire FS
» Power Poll
Permissions in this forum:You cannot reply to topics in this forum
Global Wrestling Alliance :: Locker room :: Employees-
Jump to:
